## Industrial Multimedia PC for IIoT and Edge AI from Aaeon: Intelli TWL01 Edge
Aaeon's Up brand has introduced the Intelli TWL01 Edge industrial computer, developed for IIoT and Edge AI solutions. This compact PC, utilizing the Intel Processor N-series platform, adapts to demanding industrial and commercial environments with its dual 4K display support and robust, vibration-resistant chassis.
The Intelli TWL01 Edge is designed to deliver superior performance in manufacturing facilities and commercial applications where high-resolution data visualization is critical. Thanks to its dual HDMI 2.0b outputs, two separate 4K displays can be connected, allowing operators to monitor important data clearly and on-site.
### Intelli TWL01 Edge Features
- Processor: Intel Core Processor N-series (previously known as Twin Lake)
- Graphics: Intel UHD Graphics, DirectX 12.1 supported
- Operating System Compatibility: Windows 11 LTSC, Ubuntu 24.04 LTS, Yocto 5.1
- Display Outputs: Dual HDMI 2.0b, 4K resolution supported
- Network Connectivity: Two RJ-45 Gigabit Ethernet ports, optional M.2 2230 E-key for Wi-Fi
- Serial Connectivity: RS-232/422/485 port
- USB Ports: 4x USB 3.2 Gen 2 Type A
- Expansion: Two expansion slots
- GPIO: 10-pin general-purpose input/output
- Audio Connections: Headphone/speaker output and microphone input
- Power Supply: 9 V - 36 V DC
- Mounting: DIN rail mount
- Design: Fanless, soldered memory, vibration-resistant chassis
The Intelli TWL01 Edge not only offers a powerful processor and connectivity ports but is also designed to withstand the harsh conditions of industrial environments. Its fanless design and soldered memory module ensure device stability in high-vibration environments. Furthermore, its wide power range from 9 V to 36 V and DIN rail mounting support allow for easy integration into existing systems.
This industrial computer, with its ability to connect two 4K monitors, particularly facilitates operators' access to real-time critical data. For example, in an airport terminal, screens placed in two directions can display flight information clearly from both sides. Similarly, it can be used in applications requiring multiple screens in shopping malls, billboards, or electronic menu systems.
The Intelli TWL01 Edge offers an effective computer solution for industrial and commercial IoT solutions with its high-performance processor and extensive connectivity options.
