IMI to Supply Specialist Ultra-High Pressure Valves for North Sea Offshore Development
Akademisyen
    ## IMI to Supply Specialist Ultra-High Pressure Valves for North Sea Offshore Development
    IMI has been selected as the supplier of specialist control valves for use in ultra-high-pressure injection systems for a significant offshore development project in the North Sea.
    These valves will operate under extremely demanding conditions with pressures exceeding 600 bar (8,700 psi) and will support chemical injection processes that help maintain flow and optimize production from deep offshore wells.
    ### Features of IMI EroSolve Metamorphic Trim Valves
    • Manages full pressure drop from high pressures like 621 bar (9007 psi) down to near vacuum levels
    • Designed to provide precise and stable pressure control
    • Controlled energy dissipation through a multi-stage pressure reduction system
    • Protects internal components against excessive wear
    • Accurate regulation at low flow rates
    • Engineered for severe service conditions
    The valves successfully passed extensive endurance tests conducted in both balanced and unbalanced configurations. These tests ensured that the valves were exposed to operating conditions reflecting real-world field scenarios.
    Roby Buyung, Head of Process Automation at IMI, stated, "Offshore production environments push engineering boundaries, especially as we move into deeper and higher-pressure fields. This project required valve technology capable of providing extremely precise pressure control under conditions where conventional designs would struggle. Our EroSolve Metamorphic Trim valves were specifically developed for these challenging applications, and their selection reflects the importance of proven and repeatable performance in safety-critical offshore systems."
    The project in question is part of a larger offshore development program and is progressing according to the client's delivery schedule.
    ### About IMI
    IMI is a global leader in fluid and motion control, providing specialized solutions that enhance safety, efficiency, and sustainability in the energy, automation, and healthcare sectors. It designs and manufactures high-performance valves, actuators, and control systems, offering solutions to complex engineering problems.
    Working closely with customers, IMI combines deep technical industry knowledge with real user insights to deliver effective and precise engineering solutions.
    Through its One IMI model, it integrates commercial excellence, market-driven innovation, and continuous improvement approaches to ensure the widespread adoption of successful practices across the business.
