High Torque Electric Drive Boosts Shredder Efficiency
    ## High-Torque Electric Drive Boosts Shredder Efficiency
    Baumüller will introduce its high-torque, all-electric drive system for shredding machines in the recycling industry at IFAT 2026. This system aims to offer high efficiency and low maintenance costs to machine manufacturers and operators.
    ### System and Technology
    Developed on the PowRex drive package, this solution combines DST2 high-torque motors with b maXX servo drives, enabling efficient and energy-saving operation in demanding shredding applications. Replacing hydraulic systems and standard asynchronous motors, this all-electric system eliminates hydraulic hoses and lubrication needs, reducing mechanical complexity.
    Compared to belted or standard motor systems, wear-prone parts like belts and pulleys are also eliminated with this system, minimizing maintenance requirements and downtime.
    ### High Torque and Stable Performance at Low Speeds
    The system is designed to generate high torque even at low speeds, supporting efficient and stable shredding of various materials.
    ### Lower Operating Costs and Increased Uptime
    Increased productivity and reduced maintenance operations lead to higher efficiency and lower total operating costs. Baumüller emphasizes that despite potentially high initial investment costs, the economic advantages provided ensure a short return on investment period.
    Reduced maintenance tasks allow for more efficient use of experienced personnel and fewer production interruptions.
    ### Integrated Control and Connectivity Features
    b maXX servo drives incorporate control, motion, and analysis functions directly within the drive. This allows for the development of control algorithms without the need for additional hardware. Furthermore, common industrial communication protocols (such as Profinet) are supported, enabling easy integration with PLC systems like Siemens.
    ### PowRex Drive System and Integrated Gearbox
    Baumüller’s PowRex system can work seamlessly with the Tevox gearbox and slip clutch developed by Nidec DESCH. This integrated solution offers an optimized powertrain consisting of a motor, servo drive, gearbox, and clutch.
    The system is currently used in WEIMA’s W5 and W8 series shredding machines, particularly in the W8.15 PowerLine model.
    ### Modernization Opportunity for Existing Machines
    The high-torque electric drive system can be used not only in new machines but also for modernizing existing shredding machines. As long as the machine's mechanical structure remains sound, the drive system can be renewed to increase efficiency and performance.
    This approach contributes to sustainable recycling plant operations with shorter implementation times and lower costs.
    Prepared with AI assistance by industry reporter Romila DSilva.
