Combined Lightning and Surge Protection for Compact Measurement Systems
    ## Combined Lightning and Surge Protection for Compact Metering Systems
    Phoenix Contact has introduced the FLT-SEC-ZP2-…-SV combined surge protective device, specifically designed for metering points. This device integrates surge protection, voltage measurement, and compatible smart metering system integration into a single compact unit.
    ### Key Features and Design of the Device
    The FLT-SEC-ZP2-…-SV device combines Type 1, 2, and 3 protection functions, ensuring standard compliance, space savings, and the integration of smart metering components. Its compact design leaves more space for common busbar installations and offers higher functional density in metering cabinets with easy adaptation to existing panels.
    Thanks to the integrated voltage measurement point, direct power supply for devices in smart metering systems becomes possible. This reduces the need for extra cabling, simplifying installation.
    ### Compliance with Main Power Supply Standards
    According to the VDE-AR-N 4100 standard, only Type 1 surge protective devices using spark gap technology can be used in the main power supply line, and these devices must not draw continuous current for their status indicators. The FLT-SEC-ZP2-…-SV meets this requirement with a fully mechanical and current-free status indicator.
    The integrated spark gap limits the follow current after discharge, preventing false tripping of main service fuses. Thus, the device can be installed in compliance with the power supply line before the meter.
    ### Protection of Sensitive Electronics and System Integration
    Offering Type 1+2+3 protection features, the device provides coordinated protection against lightning and surge-related hazards, making it ideal for protecting sensitive electronic devices.
    In smart metering systems, the device enables connections for the auxiliary application area (RfZ) and the metering termination point (APZ) with two defined voltage outputs, ensuring order and standard compliance in system integration.
    ### Models Compatible with Network Configurations
    The FLT-SEC-ZP2-…-SV is available in four different variants, suitable for TN-S/TT and TN-C network systems. With impulse current carrying capacities of 7.5 kA or 12.5 kA, it meets different protection needs.
    With this product, Phoenix Contact addresses the need for compact, standard-compliant, and integrated protection solutions.
    ### FLT-SEC-ZP2-…-SV Features
    • Combination of Type 1, Type 2, and Type 3 protection functions
    • Compact design, suitable for busbar mounting
    • Direct power supply with integrated voltage measurement point
    • Mechanical and current-free status indicator
    • Limitation of follow current with integrated spark gap
    • Two defined voltage outputs: Auxiliary application area (RfZ) and metering termination point (APZ)
    • Compliance: Full compliance with VDE-AR-N 4100 standards
    • Network compatibility: TN-S/TT and TN-C
    • Impulse current carrying capacities: 7.5 kA and 12.5 kA
    Editor: Maria Brueva, Induportals – AI-powered rewriting.
