## Beyond IoT: New Digital Foundations for Resilient Industry
In industrial transformation, it has become critical not just to connect devices, but to organize data, apply intelligence in the right place, and support the people managing complex operations.
For many years, the Internet of Things (IoT) promised to transform industrial operations. If everything were connected, organizations would gain unprecedented visibility into the performance of their systems. However, simply establishing connections did not bring the expected breakthroughs.
While industrial enterprises generate large volumes of data, the architecture to convert this data into reliable insights and meaningful operational decisions has often been lacking or nonexistent. The next phase of transformation must be built on a robust digital backbone. This requires systems that go beyond merely connecting devices; they organize data, utilize intelligence at the most effective point, and support the people managing complex operations.
This transformation is taking shape in three key areas:
- Transitioning from connection to context by turning fragmented data into meaningful intelligence.
- Utilizing intelligence at the edge by directly integrating AI models into field equipment.
- Creating digital systems not just for machines but for people, where technology empowers both operators and leaders.
### Transitioning from Connection to Context
In many industrial environments, digital systems still operate in silos. Operational technology (OT) platforms generate machine data, while IT systems manage enterprise information such as production planning and maintenance tracking. Energy management and sustainability reporting are often handled with separate tools, making it difficult to understand operations holistically.
When these systems operate independently, a complete picture of the plant-wide situation cannot be seen. Device alarms are visible, but their broader impacts are not understood. Without a unified view, the effect of events on the factory floor on overall performance cannot be grasped.
One reason early IoT projects failed to meet expectations is the lack of context in the data. Even if data is collected and shared, its transformation into operational insight is difficult because it cannot be organized and contextualized.
When data is collected from devices to energy infrastructure and enterprise systems, it becomes possible to understand how daily operational decisions affect broader business outcomes. This context creation is the most important first step after IoT.
### Utilizing Intelligence at the Edge
In early IoT solutions, there was an expectation that all data would first be sent to the cloud, and then decisions would be made. However, in industrial environments, most decisions must be made immediately and locally. When safety or product quality is at stake, seconds or even milliseconds cannot be waited.
Edge computing is becoming a critical part of modern industrial architecture. Artificial intelligence and analytical models can be run directly on systems near the equipment. Instead of sending every data point to the cloud, these systems process data locally, enabling faster and instantaneous responses.
For example, predictive maintenance models running at the edge can detect abnormal vibration patterns in motors or pumps and alert technicians before a failure occurs. Operational analytics can also be sent from central platforms to equipment, allowing for instantaneous application of insights.
Edge intelligence also increases resilience. In places like offshore platforms, remote energy infrastructure, and distributed facilities, continuous connectivity is not guaranteed. Systems must be able to continue operating even when network connectivity is lost, and synchronize data when connection is restored.
### Bridging IT and OT
Historically, information technology (IT) and operational technology (OT) teams worked in different areas, with different priorities and technologies. IT systems focused on enterprise data and applications, while OT systems controlled real-time physical processes. Today, these two areas can work together.
Digital transformation necessitates the integration of these areas. This requires interoperable platforms that enable existing equipment to connect with modern digital services.
This demand for data integration is closely linked to the rise of artificial intelligence. Organizations are investing heavily in AI to improve operational decisions, but the foundation for this is the quality and accessibility of operational data.
Artificial intelligence needs data. Without strong data foundations, even the most advanced AI tools cannot yield meaningful results.
### Human-Centric System Design
Technology alone cannot bring industrial transformation. The human factor is still indispensable. Operators are responsible for interpreting insights and taking action. If digital systems overwhelm users with data or fail to present information clearly, the value of the technology diminishes.
At the same time, industrial organizations are facing a significant workforce change. Many experienced employees are nearing retirement, and the knowledge gap is growing. Capturing operational knowledge and transferring it to the next generation has become a critical priority.
Digital platforms can address this challenge by providing contextual insights, guiding troubleshooting processes, and making operational data more understandable. These systems combine automation with human expertise; they do not replace it.
### A New Industrial Foundation
The next phase of industrial transformation will be defined not by the number of connected devices, but by the strength of the digital foundations that support them.
Organizations that can transition from connection to context, utilize intelligence at the edge, and build human-centric digital systems will adapt better to the rapidly changing industrial environment. These changes will enable a better understanding of operations, more effective responses to disruptions, and the creation of new value from the data generated across the facility.
For true transformation, organizations will need to build systems that convert connected data into intelligent action.
