Akademisyen
Banner Engineering's new QM30VT3 three-axis vibration and temperature sensors offer enhanced integration flexibility with an IO-Link connection option. These sensors provide significant improvements in early fault detection with their ultra-low noise third axis and built-in machine learning algorithm.
As manufacturers strive to reduce unplanned downtime, they continue to seek practical solutions without increasing system complexity. The QM30VT3 maintains high-performance vibration sensing and diagnostic capabilities while reducing PLC integration and control logic burden with IO-Link support.
### IO-Link Connectivity with QM30VT3
With IO-Link, QM30VT3 sensors can provide data output in both metric and imperial units, in either floating-point or integer format. With user-defined profiles, cyclic data can be limited to only the most important overall values, simplifying PLC programming. Once configured via IO-Link, the sensor can also operate as a smart vibration switch, allowing its use even in systems without an IO-Link host.
### Three-Axis Vibration Sensing and Ultra-Low Noise
The QM30VT3 performs true three-axis vibration sensing on the X, Y, and Z axes, providing comprehensive machine health monitoring regardless of mounting orientation. Ultra-low noise performance on all three axes increases measurement reliability and allows for flexible mounting in confined spaces.
While other three-axis MEMS sensors often experience increased noise on the third axis, the QM30VT3 ensures consistently low noise across all axes, accurately detecting issues such as imbalance, misalignment, looseness, and bearing wear in motors, pumps, fans, conveyors, and gearboxes.
### Wide Frequency Range and High Resolution
The QM30VT3 operates from 6 Hz to 5.3 kHz, enabling monitoring of both low and high-speed equipment. Its upper bandwidth, exceeding the traditional 4 kHz limit, captures high-frequency impacts indicative of bearing and gear faults.
Users can optimize resolution according to machine speed with the frequency maximum (FMax) setting. Higher FMax values offer a wider frequency range, while lower FMax values increase sampling time, allowing for more detailed analysis on slower machines. Additionally, the high-frequency envelope (HFE) feature filters out low-frequency process noise, improving the detection of bearing and lubrication problems.
A 26.8 kHz sampling rate supports detailed analysis of short-duration transient events, contributing to early detection of developing faults.
### Built-in Machine Learning and VIBE-IQ
The QM30VT3 continuously analyzes vibration data on all axes with its built-in machine learning algorithm, VIBE-IQ. The system automatically identifies baseline patterns and establishes warning and alarm thresholds without external analysis software or vibration expertise.
This feature reduces the sensor's dependence on external control devices, simplifying installation in both new and retrofit applications. As a result, fewer false alarms and earlier fault detection are achieved, supporting the transition from reactive to predictive maintenance.
### QM30VT3 Configurations and Application Areas
The sensor is available in line-powered and wireless battery-powered versions. Wireless models offer vibration sensing, radio communication, and battery power in a single housing, or with the option to separate the sensor and radio based on mounting constraints. MultiHop radio support enables the transmission of vibration data to central gateways across the facility.
Line-powered models support continuous monitoring and direct industrial controller integration. Battery-powered models offer an operating life of over 24 months, depending on reporting intervals.
### Technical Specifications
- True three-axis vibration sensing (X, Y, Z axes)
- IO-Link connectivity with data output in metric and imperial units
- Frequency range: 6 Hz - 5.3 kHz
- User-adjustable maximum frequency setting (FMax)
- Sampling rate: 26.8 kHz
- Ultra-low noise performance on all axes
- High-frequency envelope (HFE) feature
- Built-in VIBE-IQ machine learning algorithm
- Line-powered and wireless battery options
- MultiHop radio support
- Compact aluminum housing
The QM30VT3 prevents costly downtime by detecting early faults in rotating equipment such as motors, gearboxes, and conveyors. With its wide frequency coverage, low noise, built-in analysis, and flexible connectivity options, it increases access to high-resolution machine health monitoring in industrial automation environments.
